what size tires?
Old Sep 21, 2010 | 10:00 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
what size tires?
well, i have 14" s/s cragar wheels, idk how wide, but they pretty wide in the back. well, one tire blew out and i need a new one. the size is p215/75r14, but it looks as if the tire is stretched out on the rim width-wise and is bout to burst on my other one. do u think its ok? or what size would be better?
Old Sep 21, 2010 | 01:33 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: what size tires?
Sounds like you should get a size that fits better width-wise,whatever that is..
Old Sep 21, 2010 | 04:02 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
They're probably wide enough to fit a 245/60R14 BF Goodrich Radial T/A, it'll go on a 7" wheel, and it sounds like you might even have 8s
Old Sep 21, 2010 | 04:14 PM
Stephen's Avatar
Car: 87 GTA
Until you know the wheel width, we can't say much about what size to go with, it is a guessing game.
No doubt somebody will pipe up & tell you to get bigger wheels (17"18") but only YOU have to be satisfied, not them.
Old Sep 21, 2010 | 04:17 PM
vinny83's Avatar
i can barely afford new tires, let alone new wheels lol. and anyway i can tell how wide the rims are, even when the tire is still on?
Old Sep 21, 2010 | 08:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
with a tape measure? measure the width of the wheel, from outermost lip to the other, if you can eyeball it, grab a square or something to help extend the line the the tape. Whatever number you end up with, take an inch off and thats the wheel size. so if the overall is 11", its a 10" rim, 9", its a 8" rim. The actual measurement is made between the bead seats on the inside of the wheel.
Old Sep 21, 2010 | 10:34 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Proper Tire Size should never be a guessing game! <86TA> metioned a good idea to start with. Keep in mind, over-sizing can be dangerous.
Look on the bright side, wide fat tires can be expensive!!!
My advice....take it to a good tire shop, have them measure the rim, and let them suggest to you something better!!!!!(size wise).
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
