Got a Set of Wheels off a 95 Camaro Today ($82 for the full set with good Tires). I know i'll need 2" spacers on all corners for my 82 Camaro. I found a rear end that i want today on a 2001 Camaro. It has Discs.
-What are the Chances that it's a Z28 with a Locker?
-Did they have Camaros in that year with rear discs and no locker rear?
-I know this is probably a really, really stupid question, but will the 95 Wheels fit on the 2001 Rear?
-Is the 2001 Rear stronger than the one on my 82?
I belive all 4th gens have posi's
pending answer 1
Im almost 99% sure
depends I belive on what rear end you have, but from what I hear, most likely.
Good luck.
pending answer 1
Im almost 99% sure
Good luck.
The rear end in your '82 has 26 spline axles, and the rear end in the '01 has 28 spline axles, which are stronger.
