been play'in the tire/wheel fitment game P.I.T.A
Old Oct 13, 2010 | 01:00 PM
bracket rs's Avatar
tires are 275/60-15 drag radials
tried 15x8 stock gm steel wheel with 4 in backspace...rubbed a little
tried 15x8 weld 3.5 backspace...looked "hillbilly" and rubbed on fender bad
so ordered 15x8 weld 5.5 backspace....rubbed inside, infact would not even bolt flush to the drum, so i cut the front corners of the inner well at
the bottom, and also trimmed the bump-stop brackets, AND added a 5/16th spacer, fit perfect, no rubbing anywhere.
next set of tires will be a little smaller, but i had these already
hope this helps someone else
don't know how the hell guy's are running 6.5 backspace??
Attached Thumbnails been play'in the tire/wheel fitment game P.I.T.A-100_0806.jpg   been play'in the tire/wheel fitment game P.I.T.A-100_0804.jpg
Old Oct 13, 2010 | 03:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: been play'in the tire/wheel fitment game P.I.T.A
whos running a 6.5" BS?
I measured my wheel, a 18x9.5 with 20mm offset, its like a perfect 5.5" or 5.55 if you wanna be picky, but it fits without spacers!
(and no, not the ones in my sig, other wheels, no pics yet, its undercover )
Old Oct 13, 2010 | 03:09 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I run 15x10 with 6.5 backspacing. You gotta cut and modify the inner wheel well.
15x8 with 5.5 backspacing should fit perfect.
antman89iroc
36
Jan 31, 2016 08:42 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
rusty vango
Sep 29, 2015 02:44 PM
