Tire rotation
Old Oct 21, 2010 | 11:17 PM
watkins316's Avatar
Car: 88 Iroc-Z
Engine: 5.7 350
Tire rotation
I have an 88 iroc factory wheels I noticed the front say front and the rear are stamped rear, is the offset different? If so does this mean i have to bust tires to rotate.
Old Oct 22, 2010 | 07:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Tire rotation
Yes and yes (unless you rotate side to side).
JamesC
Old Oct 22, 2010 | 07:21 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Tire rotation
Tire rotation with IROC wheels and directional tires can be a expensive practice. Reason: you need to dismount the tires for a front to back rotation.
Old Oct 22, 2010 | 07:41 AM
watkins316's Avatar
Car: 88 Iroc-Z
Engine: 5.7 350
Re: Tire rotation
Just curious why did they set the wheels up that way?
Old Oct 22, 2010 | 08:10 AM
DJP87Z28's Avatar
Re: Tire rotation
GM...enough said.
Old Oct 22, 2010 | 08:14 AM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
Re: Tire rotation
They had to offset the front out more because of the size tire they wanted to run on the front. If they had the same offset, the front tires would rub when the tires were fully turned. This is something you can do if you can, find another set of front rims like yours and put them on them back. If you do that then you would have the same offset all the way around then from then on you can rotate front to rear with no more problems.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
mfp189
Sep 27, 2015 09:25 AM
