Tire Questions
Car: 1987 camaro LT
Engine: 350, L98 Heads, HSR
Transmission: TH350
Axle/Gears: 12 Bolt 33 spline 3.55 posi
Tire Questions
Alright so I am looking at getting new rims and moving up a size to 17. I found new ZR1 rims I liked but once I saw them on a third gen they didnt look right. Anyway I want to start running my Camaro at auto-x, road race events. I was wondering is it better to have more tire than rim(in other words 16inch better than 17in?) or is better to have more rim than tire.
Best Regards
Best Regards
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wheel Of Fortune
None is better per se.
More tire than wheel is what you want if you have to deal with potholes and other ruff road problems.
More wheel than tire is what you want if the majority of roads in your area are basically problem free.
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
Happy Racing!
Car: 87 GTA
Re: Tire Questions
Since you asked about aut0-x & road racing, I'd say 17s will suit your needs better.
For street use, 17" will also be fine most of the time, just slow down for potholes & bad road seams.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Tire Questions
there are many other companies that make lighter 2 pc wheels at a lesser cost, but still a few hunderd per wheel
Car: 87 GTA
Re: Tire Questions
When doing searches at places like Tirerack, look up wheels by an older BMW 3-series (3-series has the same lug pattern, IIRC). Same lug pattern, fit right on, if you get the backspacing right.
Other than that, there are still some that will come up as fitting 3rd gens.
