17'' wheels.....help!!!!!
Old Dec 27, 2010 | 02:50 PM
BadRS91's Avatar
Car: 91 RS
Engine: 305 TBI
hey guys i have a 91 RS with factory iroc wheels off a 86 was debating on moving up to 17'' wheels since thats about the starting point for most aftermarket wheels. was wondering what exact size of 17'' wheel and spacer for front and rear to maintain stock look.... any help would be great!!!
Old Dec 27, 2010 | 03:26 PM
Stephen's Avatar
Car: 87 GTA
Re: 17'' wheels.....help!!!!!
A 17" wheel does not automatically mean you need a spacer. The backspacing (or offset) is what determines the need for a spacer & if your willing to modify the inner fender panel to avoid using a spacer.
A here on TGO will tell you EVERYTHING you need to know about fitting bigger wheels.
Old Dec 27, 2010 | 06:14 PM
BadRS91's Avatar
Car: 91 RS
Engine: 305 TBI
thanks ill keep searching to find some more info additional info much appreciated thanks
Old Dec 27, 2010 | 08:08 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I have a set of 17X8 wheels on my 92 with zero offset on all four with no problems whatsoever. Same goes for my 89 with 17X8.5 and 26mm offset on all four. No spacers required on either car.
Old Dec 27, 2010 | 08:35 PM
BadRS91's Avatar
Car: 91 RS
Engine: 305 TBI
what size tires are u running front and rear on your 92? (Al Hasse)
Old Dec 27, 2010 | 08:46 PM
Al Hasse's Avatar
Same size on both cars...
245/45/17 on all four
Old Dec 28, 2010 | 02:10 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
im running the same size tires on 17 inch iroc replicas. i didnt use any spacers adapters or even the factory rear spacers that came on irocs. i have a 1.5 inch drop and have not had any problems with rubbing or contact anywhere in the wheel wells.
