1992 Camaro Help
Old Dec 30, 2010 | 02:55 PM
INeedaRS's Avatar
1992 Camaro Help
Today, I went to buy tires for my 92 Camaro RS. I want to take my front tires off (they're trash) and put the back tires (perfectly fine) to the front.The mechanic said that the tires I have are no longer available. The mechanic said that he can order tires that went onto the 92 Z28, that size is 245-50r 16. My question is will it fit and work for my car?
Thanks!
Old Dec 30, 2010 | 03:10 PM
Shane B's Avatar
Car: 92 RS
Engine: 5.slow
Transmission: 5speed
Re: 1992 Camaro Help
As long as u have 16 in wheels then yeah it will work.Ive got that size all around on my 92 RS.
Old Dec 30, 2010 | 03:28 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Your mechanic sounds a bit suspicious. The original equipment tire is a 215/65/16, those are still widely made. Unless your talking about a specific brand of tire not being available and not size, you may look to get tires somewhere else. Just my
Old Dec 30, 2010 | 10:04 PM
INeedaRS's Avatar
Does the wider tire help with traction and stability for you?
Thanks, Im going to check with another mechanic, but i'll get back to you on what kind of tires I have i cant think off of the top of my head the kind I have...
Old Jan 2, 2011 | 04:33 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Just look at the tire to see what size it is. 245 or 215. 245 was an option while 215 was stock.
The exact brand of tire may not be available, so your mechanic may be correct (if that is what he is referring to).
Go to tirerack.com to check pricing.
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
