Replacing only one bolt from hub. How to?
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hello,
Please, help with this. I need replace a broken bolt from hub. How to get out the bolt?
Ideas, suggestions, pictures, tools needed.
Any help will be apreciated. Any little idea is useful too.
Thanks in advance,
Denis V.
Thanks in advance,
Denis V.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Replacing only one bolt from hub. How to?
take off the rotor and knock it out with a hammer. then knock the new one in
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
just use an socket extension or another bolt that will fit to knock the bolt out.. then put the new stud in and use a nut or open lugnut that fits it and tighten it down untill it is all the way in.. i do it atleast once a week at work
Engine: gone
Transmission: gone
Axle/Gears: gone
Front hub? or rear axle flange? Front's hub and rotor have to come off. Then knock out stud with hammer. Then place stud back in. put a couple washers on the front side and use a open ended nut and pull stud back through til flush on backside. Rear is basically the same. But its just on the axle flange...
Axle/Gears: No idea
Oh, thanks very much.
I 'll try this weekend in order to pass local technical & emission test.
My local law says: "Wheels completes, with all bolts & nuts".
Denis V.
Denis V.
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
If it's the a stud on a front disc setup they're pretty easy. Hammer the old one out and put the new one in and use a lug nut (I prefer open ended for this) and tighten it down to pull the new stud through - Shouldn't take more than 15 minutes.
evilstuie
Jan 9, 2020 08:29 PM
