Problems: 96 WS6 Wheels
Old Feb 26, 2011 | 11:50 AM
Smoothy's Avatar
Car: 89 Camaro RS
Hi,
I wanted to install 96´ WS6 Wheels on my front. I have use LS1 brake discs and 50mm(1,97") Spacer. Now I have the problem that the tie rod end grinds on the rim. Are there narrower tie rod ends or other steering knuckle?
96-01 Polished WS6 Trans Am Wheels
Size : 17" x 9"
Backspacing : 6.875"
Bolt pattern : 4.75"
Old Feb 26, 2011 | 04:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Problems: 96 WS6 Wheels
no, you need slightly larger spacers, or if its not touching the tie rod by much, you can grind the spindle a little, but just a little, too much and you can have a failure
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
dbrochard
Sep 7, 2015 09:41 AM
