Max Tire/Rim Size
Car: 1984 Camaro
Engine: 5.7L V8 (350)
Transmission: TH350
Axle/Gears: stock
Max Tire/Rim Size
whats the max tire size, width wise for an 84 'maro? i wanna put drag radials and don't know how wide they can be (rear)
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Max Tire/Rim Size
With some minor modifications, you can fit a 315. I think someone here was even running 325 M/T's. The height though I wouldnt worry about as much. What height tire you run has more to do with the setup of the car, as it effects rpm at any given speed.
If your going to run as wide a tire as possible, I would make sure you have an adjustable panhard rod to center the axle in the body.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Using the Search feature here on TGO, I found:
https://www.thirdgen.org/forums/sear...archid=3912220
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
