Will these tires fit without mods?
Old Apr 12, 2011 | 11:11 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
I have a set of maxxis bravo m/t 295 50 16 tires that i plan on using on my Rear, Im running the GTA rims in the back which are 16x8.
Will i have to cut off the inside of the wheel well? or is it a direct fit?
Anybody using this size?
Old Apr 13, 2011 | 10:08 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Will these tires fit without mods?
They should fit, 295 is the widest you can run stock without modification.
Though on an 8'' wide wheel they will have a lot of side wall flex while cornering. I dont recommend a tire wheel combo on the street.
I was running the same size mickey tompson et streets on my 16x8 Iroc wheels. Nice on the track, but pretty crappy on the street. I changed my setup being I only go to the track seldomly.
Old Apr 13, 2011 | 10:20 AM
Car: 1986 Iroc-Z
Engine: 355
What do you mean by sidewall flex? Will it rub on turns?
Old Apr 13, 2011 | 01:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
No, won't rub. What he's saying is that with such a "tall" sidewall, when you take a fast corner, the sidewall will give some - the wheel will start to roll over onto the sidewall kind of. The longer anything is, the easier it bends - a "tall" sidewall will start to 'bend' under pressure in a hard turn.
Old Apr 14, 2011 | 08:20 PM
Car: 1985 IROC-Z
Engine: 355
Usually making the car lean and feel more loose/boaty in turns. Not a problem when going straight.
Old May 3, 2011 | 02:49 PM
myzblubyu's Avatar
Car: 1990 Iroc, 1984 Buick Regal
Engine: 5.7, ZZ4 crate w/FIRST injection
Transmission: 700r4, 700r4
Axle/Gears: 3.73, 4.11
I have BFGs 295/50/16 on a factory 1990 IROC rim and I had to take a hammer to the inner front fender well and they still rub a little on a hard launch or a country road. My car has been lowered with Eibachs pro kit. Enjoy, Tim
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Djmathis123
Aug 24, 2015 02:53 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
matthew911
Aug 12, 2015 09:38 AM
