Widest tire I can run???
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Hey guys, im keeping this one real simple, 83 Camaro, got a set of Cragar Street Pros. theyre 15's. What's the widest tire that I can run without any clearance issues. The rims are 8 inch wide wheels. I can get a set of BF Radial Ta's either 255/60 or 275/ 60 for the same price but am not sure if the 275/60s will clear with zero issues! The car is very clean and I don't want it to look goofy. My current wheel/tire set up are staggered 17x10 and 18x10 Corvette wheels with Eagle F1 run flats 275/40 in the rear. I love the way the wide tires look but I'm not sure if I can run such a wide tire on my Cragars with no rub. Vette wheels are very very deep with no rub. ANY INPUT WOULD BE AWESOME! I need to get tires within the next couple weeks! Pictures would also be much appreciated of your tire set up!
Thanks guys!
Thanks guys!
Guest
Posts: n/a
Re: Widest tire I can run???
What fits will depend on the backspacing. If it's 4.5" including the lip, then 255s might be okay up front, I'm not sure. If it's 4", then use a 235/60R15. That one I do know. That barely cleared.
If you have 1LE brakes, that changes things. Then a 4.5" BS with a 235, I think.
eightsixseven
Dec 16, 2024 01:50 PM
