Oven Cleaner on Alumin Rims
Old Aug 1, 2011 | 07:51 AM
WSX123's Avatar
Car: 1988 Trans Am GTA
My wife decided to put oven cleaner on her rims to try and clean the caked on brake dust, she left it on too long and now the clear coat turned white in some places. but from a distance they shine real nice lol
any recomondations on how to remove to get them back to normal.
Old Aug 1, 2011 | 08:14 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Oven Cleaner on Alumin Rims
wife should have known!!!! Easy off will seriously pit & etch into aluminum
get the rest of the clear coat off steel wool and re-clear
PS can says DO Not Use on Aluminum!!!!!!!
Old Aug 1, 2011 | 08:46 AM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Lol hahahahahahaha See what happens when you cut corners.
The only way to fix that is to refinish them.
Old Aug 1, 2011 | 04:17 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
My wife filled the radiator with water one day. Only it wasn't the radiator. And it took more water than she thought it would.
Old Aug 3, 2011 | 09:58 AM
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Transmission: 6 Speed
Axle/Gears: 3.71
Now I am curious, so what did she fill up?
Old Aug 3, 2011 | 12:02 PM
TallTim's Avatar
She removed the oil fill cap and filled the engine with water. While it was running. Amazing it didn't kill the engine. Engine started idling rough so she shut it off. Fortunately two back to back oil changes and we put another 20K uneventful miles on the car. I've never seen oil the color of light chocoloate milk until then...
This could make a good thread. Scariest things we've done to our cars and lived to tell about...
Like... I was breaking in a rebuilt engine at 2200rpm when I noticed the fresh paint on the water pump melting off. What? Why would dry paint be melting? Well if the fuel line had been worn through by the fan belt and the belt picked up and flung a mist of fuel all over the place that might explain it. Hmmm.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
zman1969
Oct 1, 2015 11:09 AM
dusterbd
Sep 29, 2015 08:40 AM
