Original Wheel Size??
Car: 85 Camaro Z28
Engine: 5.7 TPI
Can anyone tell me if the 1985 Camaro Z28 was originally equipped with 15 or 16 inch wheels?
If it orginally came with 15's, what would I need to do to fit 16 inch iroc single lines?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Original Wheel Size??
they bolt right on, you need to do nothing
Car: 86 Trans Am
the only difference is a slight change in the length of the front steering stop. other than that, they will fit no differently on your car than they would on a car that had the 16' from the factory.
even the steering stop is almost a non issue. I have the 16x8 crosslaces on my 92 bird that had stock 15" wheels, and i dont have any abnormal issues with clearance and rubbing. I dont even have steering stops FWIW
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might find the following info interesting:
https://www.thirdgen.org/forums/susp...s-created.html
JamesC
JamesC
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
