quick ZR1 rim question ( already searched )
Old Sep 18, 2011 | 09:22 PM
ssj2link's Avatar
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
okay so i picked up a set of ZR1 wheels for stupid cheap and now i need to mount them to the car. i read most people have the 17x9.5 with a 50 mm offset well mine are stamped 54 mm offset. i did the calculator from skulte and i get 2.12 front and 1.27 rear ( i have done it over and over and over again ) now what i need to know is obviously the 2" spacer is too small so what i need to know is will the 2.25 front and rear fit the car okay or will they stick out too far? 86 trans am with an 88 posi 3.27 9 bolt rear. i need a quick answer if possible
Old Sep 18, 2011 | 09:37 PM
TLS_Addict's Avatar
Car: 1999 Camaro SS
Engine: 440ci LS
Transmission: T56 Magnum
Axle/Gears: Dana S60 w/3.73 gears
Re: quick ZR1 rim question ( already searched )
I hope my mind is not going back but I think the older F-body rears are narrower than the later ones, which these fit just fine.
Is your 9 inch rear made to the same width spec as stock?
Old Sep 18, 2011 | 09:38 PM
ssj2link's Avatar
Engine: 5.7/5.0
stock third gen yes
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
antares57
Aug 6, 2015 07:47 AM
