tire size? HELP!!
Old Oct 2, 2011 | 12:23 AM
92camaroracer's Avatar
Car: 91 z28
Engine: 383
Transmission: t-5
tire size? HELP!!
need some help, i purchased the 18" iroc wheels and since they ony come in 8" i need to know what the widest tire i can put on the rear wheels is. im swapping in a 383 so i would like to have some decent rubber back there. also does anyone know how much it may be to have the rear wheels widened? thanks in advance
Old Oct 2, 2011 | 07:29 AM
Car: 91 z28
Engine: 383
Transmission: t-5
Re: tire size? HELP!!
i know if i did some research on here i could probaby find out, but i am currently in afghanistan and have sort of a time issue, any help is greatly appriciated.
Old Oct 2, 2011 | 08:18 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Typical widening cost is $200 per wheel, up to 3". IIRC, you can save $50 each by supplying a donor wheel for them to cut the inner section from.
They can provide you a quote via email, so your location won't matter for that.
http://www.wheelsamerica.com/index.php?page=main
As for tire size...Can't say much until you decide on a wheel width.
Old Oct 2, 2011 | 08:55 AM
Car: 91 z28
Engine: 383
Transmission: t-5
how wide can i go without having to do any tubbing work, i was thinking 9 maybe 9.5?
Old Oct 2, 2011 | 09:01 AM
Car: GTA
Depends on your definition of "tubbing". I fit 11" wheels with only some cutting with a 3.5" grinder & hammering with a mini-sledgehammer. And they fit completely under the fender lip.
I sent http://www.wheelsamerica.com/index.php?page=main my 9" wheels & had them widened to 11". Went from 5" bs to 7" bs. I only cut body sheetmetal & didn't add any.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
