slick size on gta wheels???
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
hi i run 13,02@111mph with 245 50 16 tires i would need to overrev the engine to 7200rpm to pass the line on 3rd gear with 3:45. i have no choice to shift in 4th gear and pass the line right after... i dont want to screw with changing gears in my 9 bolts BW rear end should i pick 28'' tall tires and pass the line at 6000rpm???
295 50 16 M/T street radial II 28 11.5 16 seems the best choice am i right???
i should have around 367whp with HP calculator..would these meet would slow me down???to big???
please help...i have a 2.00 60' my car should run low 12s!!!!
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: slick size on gta wheels???
this is a manual trans? if so you want to be in 4th gear, which is 1:1 at the strip. If anything you should have taller gears in the rear so you'd be at shift rpm in 4th for best ET
yes it it 5 speed manual...but i dont have acces to gears in that 9 bolts...i prefer to go with tires...whats wrong with hiting the line in 3rd gear i am waisting my 4 gear anyways???
Car: 1987 IROC Z / 1999 Suburban 2WD
Engine: Lingenfelter 383 / Vortec 350
Transmission: 700R4 / Built 4L65E
Axle/Gears: Stock / 4.56 Locker
I would think that high in the RPM band that you would start losing power anyway. I would not recommend going with a 2 inch taller tire but maybe moving to a 26 x 10.50 et street. Have you tried shifting a couple hundred RPM sooner in each gear to see how that affects your ET? IMHO a 2 inch taller tire is going to kill your 1/4 mile.
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
