Please help, i cant FIGURE IT OUT!
Old Nov 11, 2011 | 02:36 PM
Goosehead's Avatar
i have a '84 camaro, with a 4th gen rearend.
And i need some new wheels/rims.
If seen some very nice wheels : 18x8 .
i think im gonna use 225 or 235 in the front
and 255 or 275 in the rear.
My question is: what offset do i need with a 4th gen rearend and 18x8 rims?
I like it to have the rims sit flush with the fenders in the rear, in front i dont mind if it sits a bit inside the fenders.
i thank you in advance.
Old Nov 11, 2011 | 07:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Please help, i cant FIGURE IT OUT!
your not going to be able to get much more than a 245/40/18 on a 18x8 wheel, it will fit the front just fine with 4.5" of BS, no point going smaller.
For the rear, i dont have the 4th gen wheels specs handy, but use the same offset as the stock 16x8. If we assume you would need a 2" spacer to use the 4th gen wheel on a 3rd gen axle, that i would assume you would need a 8" wheel with 6.5" of BS to fit the 4th gen rear, since they are about 2" wider on each side than a 3rd gen rear. That will fit the car nicely
Old Nov 12, 2011 | 03:05 PM
Goosehead's Avatar
thanks.
Old Nov 12, 2011 | 03:21 PM
3rd Coast Z's Avatar
Car: 1987 IROC Z / 1999 Suburban 2WD
Engine: Lingenfelter 383 / Vortec 350
Transmission: 700R4 / Built 4L65E
Axle/Gears: Stock / 4.56 Locker
I wouldn't necessarily recommend it, but I have squeezed 275's on an 8 inch rim. The sidewall bulges a bit but other than that it is just a pain in the *** to get them on.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
