need help with wheels
Old Jan 23, 2012 | 07:30 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
Transmission: world class T5
Axle/Gears: borg warner 9 bolt
I've been reading on here for a while now and still cant seem to find a straight answer or just confuse myself i want to run 17x9s with 275/40s on all corners without spacers can it be done?what wheels? thanks for any help
Old Jan 23, 2012 | 07:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: need help with wheels
sure it can be done, you just need the proper backspacing, which should be somewhere between 5 and 5.5" based on the sticky at the top of the page and my mental thinkings. It has a lot to do with what brakes you have on the car and if you plan to ever upgrade them since the brake upgrades move the wheels out more
Old Jan 23, 2012 | 08:26 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
which backspacing would be better as far as clearence for a 275? how much is to much? i have stock 92 rs brakes not upgrading anytime soon i have read the sticky an it says you can only run a 255 up front with a 17x9 an 5/5.5 of backspacing?
Old Jan 24, 2012 | 09:18 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
is this info correct
http://www.camarotech.com/WheelsAndTires.html
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
