Tires for 16" wheels
COTM Editor (Retired)
Car: 89 Formula 350, TTA
245/50's are fine for the front, but what if I want something a little wider (like about a 275) in the back? do they make a tire (preferably a Z rated tire with directional tread design) that is wider than 245/50/16, but not taller? 255/50/16's are noticeably taller but not noticably wider and therefore suck.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Tires for 16" wheels
BFG makes a 295/50, but it isn't a z-rated pattern, I believe it is H-rated.
If you use the
feature here on TGO, you will find this same subject talked about over & over & over and you WILL find the answers you seek.
If you use the
feature here on TGO, you will find this same subject talked about over & over & over and you WILL find the answers you seek. On Probation
Engine: several
Transmission: none
Axle/Gears: none
Not anymore. You search tirerack.com. The 295/50R16s are history, because they were priced far too high to sell, nearly $200 each.
