what size front skinnies
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
needing to buy new front runners for my car. what size should i run? 26/4.5 or 27.5/4.5? i like the look of 27.5s and they will give me a little more header and ground clearence. but i have heard the 26s are faster... you guys tell me.
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Re: what size front skinnies
I'll throw my thoughts in on this, I'm more partial to the 27.5" tall tire. I prefer the way it fills the wheel well, and the additional ground clearance is a bonus. I read somewhere that the smaller dia tire will roll through the beams faster so that will affect your time... not sure if thats true or not. So my vote goes for the 27.5"... mostly for looks.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
There's not many drag only cars here on this site. Id love to see a photo.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
the larger di tire stays in the beams Longer.
letting you start your role out just a fraction of a sec faster (Ball park).
ya can cut a better light. hitting it on the yellow we all know this.
and somtimes the shorter Tire (25")tall might give you a red light.
the lager Di Tire helps with this.
i my self use a larger tire in the front, to stay in the beams Longer.
ya just have to hit the yellow Just right..(kill them with the Hole shot)
and run almost right on your Dial in.
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
