Camber Wear
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Camber Wear
Rotate tires more frequently. This can also be caused by too much toe. There is not need to run that much camber on the street
Car: 1985 firebird
Engine: 350 .40 over
Transmission: 5 speed borg(NWC), ram clutch
Axle/Gears: ROTATING MERCURY DRIVE.
Re: Camber Wear
what he said check to see if you have to much neg.toe inwards. i had a car that did this and i just brought it to my front end shop and showed him the problem and he corrected it
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Camber Wear
ive been meaning to get an alignment and it kind of just slipped my mind -__-
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Camber Wear
Doesn't look like camber wear to me. Excessive negative toe, when the wheels are toe in looks like that. Camber tends to wear not as aggressive.
If the other tire is worn the same, then that's your dead give away that its toe. IF not there is definitely something wrong with the front end causing the camber to wear that harsh. Ball joints, control arm bushings, strut mounts...could be a lot of things.
Toe wont wear one tire.
morrow
Jan 13, 2024 12:29 PM
rb85TA
26
Sep 14, 2015 10:29 PM
