86z28 widening rims
Car: 1986/90 camaro
Engine: 350 tpi
Axle/Gears: 3.73 gears. POSI
86z28 widening rims
has anyone ever widened the rear rims off the 86 z28 to a wider size? i am looking to widen mine for a wider tire, and if so how wide? and what size tire?
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: 86z28 widening rims
you need to look up the avaliable tire size for 16in tire and go from there then you can see how wide you can go on the wheel
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
It's been done by another member here. I believe he had 1.5" added to it. Here I took the time to even look it up for you: https://www.thirdgen.org/forums/whee...y-90-iroc.html
Overall yes it does look different. Going up 1.5" isn't going to make a bunch of difference on the tire selection normally. It just comes back to personal opinion. If you're not attached to your rims it would be easier to just replace them. Jegs has a sell on aftermarket ones now for $90 to $120 each which is very reasonable even on their knock off designs.
Engine: 305 to 350
Axle/Gears: 10 Bolt
the price for new tires and cost to widen them shipping etc vs just buying aftermarket wheels used or new your prob going to spen 150 to 200 per wheel to widen and the $ to performance gain is it worth it is another thought
and ive seen that thread and he wanted to go wider but tire selection the wider you go gets slimmer 9 - 9.5 would be safe
which a 255 would be ideal or 275 depending on how much stretch or bulge you like
but its personal preference and it would look good if its done right if your going for the sleeper loook
Car: 1986 IROC-Z
Axle/Gears: 4:10
IMO it looks great when its done right. I've seen users that have had them widened to a 10 inch or so.
morrow
Jan 13, 2024 12:29 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
