I-ROC RALLY HELP
Old Oct 24, 2012 | 03:36 PM
KC_Reaper's Avatar
Car: 1992 Camaro RS
Transmission: N/A
Axle/Gears: N/A
I-ROC RALLY HELP
i have 4 iroc rally in the problem is they are all REAR rally what i like to know is are the front & rear seting just for camaro & iroc or all chevys ? are can i put all rear rally on my 83 Monte Carlo ?
Old Oct 24, 2012 | 04:06 PM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
Re: I-ROC RALLY HELP
I believe for camaros, just the IROC and 91-92 Z28 wheels have different offsets. The cars themselves don't differ, just the wheels. As for using all four rears, I have no first hand knowledge, but I'm sure someone here does.
Old Oct 24, 2012 | 04:13 PM
KC_Reaper's Avatar
Car: 1992 Camaro RS
Transmission: N/A
Axle/Gears: N/A
thats a start. THANKS
Old Oct 24, 2012 | 07:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it was done to help the car track better. You cna run fronts on the rear, but the rears will not fit the front without a spacer, they will hit the strut and probably the tie rod
I dont know about the monte. It has a different front suspension, and i dont know offhand what offsets it uses.
Brother Al
Oct 14, 2015 06:39 AM
Papaginos
Sep 27, 2015 03:29 PM
84berlinettaV6
May 9, 2002 08:09 PM
CrazyHawaiian
Mar 16, 2002 10:35 AM
hot86z-28
Dec 28, 2001 11:44 PM
