Got a present from fed ex today!
Old Feb 19, 2013 | 07:34 AM
  #51
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: Got a present from fed ex today!
Originally Posted by hellz_wings
nice! how much does one weigh? and does it keep the wheel centerline in the same place?
The wheel centerline went up just about a half inch. Not as bad as i had anticipated! I didn't weigh each wheel but it's about the same as the old 16 inch cragars I had on there.
Old Feb 19, 2013 | 07:35 AM
  #52
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Originally Posted by IROCgiraffe
Can't wait to see this IROC lowered and the IROC-Z center caps on the wheels!!! FTW
No worries, it's on the agenda
Old Feb 19, 2013 | 07:37 AM
  #53
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Originally Posted by BADNBLK
They look nice on there, but I agree it needs to come down to earth a little more
What springs is it running?
Thanks. I'm pretty sure the rear springs are stock and the fronts may have been worked down an inch by the PO.
I'm thinking of going the route of sportlines. Maybe have to cut a little off the coil on the back to level it out. I'm not a huge fan of the raked third gen look.
Old Feb 21, 2013 | 10:52 AM
  #54
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
looks great man. really nice clean look... i might have to grab myself a set of those
Old Feb 21, 2013 | 05:47 PM
  #55
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
Those look great man! Your car overall is really clean. I think you'll like the Sportlines, I do.
Old Feb 22, 2013 | 02:10 PM
  #56
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Thanks! Once I get my taxes back I'll look into picking some up. I have plenty of time before spring hits. While I'm at it, I'll probably put on some slotted / crossdrill rotors. Might as well since I'll have the front end apart.
I'd like to put on a hurst shifter, but it's not a priority. Looks like i'm almost ready for spring cruising!
Old Feb 22, 2013 | 04:05 PM
  #57
85_ZED28's Avatar
Car: '85 Z28
The wheels look good. Soooo much better than chrome. Imo, if you're using the stock T5 shifter, an aftermarket shifter certainly should be a priority!!
Old Feb 24, 2013 | 07:58 AM
  #58
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Yeah I have a stock t5 shifter. It's real sloppy.
Old Mar 2, 2013 | 01:54 PM
  #59
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Ruckus, those new rims and tires look amazing! I agree that the stance needs a little work but wow what a difference a set of boots make.
Old Mar 5, 2013 | 08:48 AM
  #60
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Thanks a lot! I'm going to go with the sportlines once i can put some money away. Just got out from being upside down on my truck and rolled it into a lease. I get bored with daily drivers too fast so I'm a poster child for leasing. I should have them ordered and on before it warms up in michigan.
Old Sep 27, 2014 | 06:21 PM
  #61
G.Ride's Avatar
Car: 1989 Iroc-Z
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.08
Any updates with stance? I'm going to get a set of these rims but will probably go 245/40/18 all around...
Linson
Oct 24, 2025 02:00 PM
bjpotter
Oct 4, 2015 07:48 PM
paul_huryk
Oct 1, 2015 04:27 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
