z06 rims
Old Jan 24, 2013 | 07:10 PM
onebad92's Avatar
z06 rims
Will they fit well on a 92 firebird? Theyre 5x4.75 x 9 I think...
Old Jan 25, 2013 | 11:51 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Axle/Gears: 10 Bolt 4.10
Re: z06 rims
size/width/backspacing?
what year C5 or C6 Z06 wheels?
Old Jan 26, 2013 | 08:43 PM
meangreen92's Avatar
Car: 91 Formula
Re: z06 rims
if they are 9 or 9.5 wide in 17-19 2 inch all around will work, wider wheels will need wider adapter, inner fender work and possible suspension rubbing. it all depends on wheel and tire size mounted on that wheel
Old Jan 26, 2013 | 11:17 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Re: z06 rims
My 18x9.5 and 18.8.5 c6s bolted right up with a 2" spacer
Running 275/35/ZR18s and only have rubbing on the inner fender well at full lock, rear is fine.
My friend's had 17x9.5 c5 z06s (cant remember tire sizes) and had no rubbing with 2" spacers
Old Feb 24, 2013 | 02:11 PM
Camarobad's Avatar
Car: 89' IROC
Axle/Gears: 373
Re: z06 rims
Need help to I got 89' IROC with 09 z06 rims 345/30-19 on the rear....what size spacer will I need...or are they to wide...don't want to do any fad to rear of car...just spacers...
Old Feb 24, 2013 | 07:47 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Re: z06 rims
Like I said for your other post, you more than likely won't fit that wide of wheel/tire in the back with just a spacer. You COULD, but you would have enough spacer that your tires would stick atleast an inch outside the fenders. It also isn't safe to have 3+" of spacers as it puts too much load on the studs.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
