biggest rim and tire combo?
Old Mar 1, 2013 | 08:18 AM
brian r's Avatar
Car: 1988 iroc-z
Engine: lq9 408 stroker
Transmission: 350 turbo
i have a 1988 iroc im plan to get 17" rims im looking for the widest tire i can fit on the back how big can i go? and what offset? if there is any way to lower it that would be good but would be willing to jack it up a inch or so and do small mods but dont wanna go threw tubbing it
Old Mar 1, 2013 | 08:53 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: biggest rim and tire combo?
CTW Motorsports sells a direct fit 17" x 9.5" wheel that fits all 4 corners. While you can fit a 11" wheel in the rear with some massaging, the choices are somewhat limited.
Old Mar 1, 2013 | 09:34 AM
brian r's Avatar
Car: 1988 iroc-z
yeah i was thinking 17x9 up front but im putting a twin turbo ls motor in so im looking for all the rubber i can get in the back if i go with the 17x11 how big of a tire can go on it? and what off set would i need?
Old Mar 1, 2013 | 03:38 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
You can run a 17x11 with a 315/35-17 tire if you roll the rear fender. If I remember correctly my rear 17x11 have a 6" backspace.
Old Mar 1, 2013 | 03:44 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
i had 4th gen rear and SS rims and ran 315 35 17 without touching a thing and ive had 325 15s with the help of a baseball bat ghetto fender roll and a BFH mini tub
Old Mar 1, 2013 | 03:47 PM
lunati397's Avatar
Old Mar 2, 2013 | 12:00 AM
brian r's Avatar
Car: 1988 iroc-z
what exactly is rolling the fender?
Old Mar 3, 2013 | 02:03 PM
Axoid's Avatar
Car: 92 Camaro RS
If you check the inner edge of the fender well you will see that there is a lip that needs to be bent upward to keep from rubbing and cutting into the tire that is as wide as a 315. There are special tools that help with this, but some people have done it with just a baseball bat the is levered against the tire.
The trick is keeping the paint from splitting or controlling it so that it doesn't cause it from flaking off on the outside.
Old Mar 3, 2013 | 11:02 PM
brian r's Avatar
Car: 1988 iroc-z
car still needs to be painted so not worried bout it lol
brian r's Avatar
Car: 1988 iroc-z
but do u know the name of the tool?
Old Mar 4, 2013 | 09:03 AM
Axoid's Avatar
Car: 92 Camaro RS
This is like the tool that I used. I borrowed the one that I used from a friend.
http://www.eastwood.com/fender-rolle...isher-kit.html
Old Mar 4, 2013 | 02:40 PM
brian r's Avatar
Car: 1988 iroc-z
wow thats alot
Old Mar 4, 2013 | 09:21 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
look at your local craigslist and type in fender rolling service. some people do it for 60 bucks all around or like 20 a fender. thats down here in so cal tho.
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
