Replacing 15" wheels.
Old Apr 16, 2013 | 09:46 PM
bandit90z's Avatar
Car: 1990 Iroc-z
Engine: 5.0
I want to swap my 15 " wheels for 16" . I have a 90 IROC with rear drum brakes.
Do I need for fronts or for rears, or front and rear with spacers?
Greg
Old Apr 17, 2013 | 12:35 AM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Re: Replacing 15" wheels.
What 16 inch wheels are you getting? The 16 inch Irocs should fit just fine with out any spacers, just make sure you get the right Tire size
-Luis
Old Apr 18, 2013 | 08:25 PM
bandit90z's Avatar
Car: 1990 Iroc-z
Engine: 5.0
The front and rear 16" iroc wheels have different offsets
Old Jun 22, 2013 | 08:14 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
yes the offset is different for front and rear. I just got a set of four from a 91 iroc for 230 dollars without any damage on them, what I see on the rims is that ther are stamped front and rear on the rim so you cant mess up putting them on the car.
cam-mike
Aug 24, 2015 07:23 AM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
