need help!
need help!
If I want to put 9.5 in wide rims on my 89 iroc what size spacers should I use 2 or 2.5 in and should they be hubcentric? Any input or experience would be greatly appreciated since ive never had to do this?
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: need help!
CTW Motorsports makes a 17" x 9.5" wheel that requires no spacers, check them out:
http://www.ctw-motorsports.com
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: need help!
9.5" can fit without a spacer, if the wheel gas the right backspace. Gotta know that to know what spacer you need.
Search and you will find your answer many times over.
