Question on spacers
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Question on spacers
Want to run 4th gen firebird rims want to know the size that i need to run 265s in back and 255s up front and have them tucked nicely like this
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Question on spacers
if stock wheels then 2"
simple search would do
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Skip the spacers & put in a 4th gen rear end. Use a 98+ & you'll get a better posi unit + bigger brakes + not have to add weight to the setup nor hafta run double (20) the lug nuts + have a lower mileage rear end which equals less wear on it.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
The car in the pic looks like it has a widebody rear fenders on it to me - could just be the angle of the shot...
Engine: 305 to 350
Axle/Gears: 10 Bolt
99+ 4th gen had torsen posi thats when the started using them
98 and down had auburn posi
you want the torsen posi ...not the auburn due too fact once it wears out its junk
yea thats a wide body 5th gen way too much junk in the trunk lol
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Agreed, Zexel is the only way to go for a Posi.
