hubcentric wheel spacer???
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Is one of these nessesary or will a regular wheel spacer do? Using corvette wheels and 1.5 inch spacer on the front with ls1 brakes.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: hubcentric wheel spacer???
Dont need hubcentric although it probably would be better. The regular bolt on adapters have worked fine in the past.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
No they are not needed .. It's a redundant safety future
As most wheel adapters are lugcentric wich means they are center by proper torquing of lug nuts
Hubcentric is centered by the hub ...
So if there hubcentric ..hence redundant safety ..but it doesn't hurt .. I spend extra to have them hubcentric as I like the tight fit ..Never hurts to be extra safe ..That's my personal opinion tho
If any thing tho I would make them wheel centric to help center wheel ... But it's also not needed if wheels are lugcentric I think most are I could be wrong tho ., I know stock thirdgen wheels where
I personally run hub and wheel centric wheel adapters and love the fit and no little vibrations either
Keep in mind front hub has a taper .. Different wheel adapter company's do not make them the same the ones I've seen... some are not exact fit while others are fit good
Usually corvette wheel guys run non wheel / hubcentric spacer
punkmaster98
Sep 8, 2015 09:45 PM
