My research searching for wide 17/18" rims
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I spent hours researching new rims so thought I'd post what I found here, I only looked for rims under $200 each that gave a muscle car look.
Cheap (not custom offset) rims will almost always require spacers to get your tire outer edge to sit stock so I opened up the search to 5x4.5" bolt pattern rims also since the adapters can change the bolt pattern.
Firebirds with 16x8 wheels have the tire sidewall sit about 1/4" outside of the outer front fender (245/50/16)
and about 5/8" inside the outer lip of the rear fender (255/50/16).
This is what I measured on my 16" gold lace TTA and used in my spacer calculations below.
FORD BOLT PATTERN
Wheelreplica.com
REAR 05-12 Bullitt or Cobra wheel 18x10 $145 free shipping
45mm offset 7.2"BS, needs a 1" ford to gm adapter, outer edge of rim will sit same as stock 16x8 wheel. Will clear fender lip. Can use a 1.25" spacer to increase inner fender clearance but will be close to outer fender lip. May need minor hammering and removal of rear bump stop
FRONT 05-12 Bullitt or Cobra wheel 18x9 $144 free shipping
36mm offset 6.4"BS, needs a a 1.25-1.5" ford to gm adapter, will sit like stock, no rubbing
You can buy the 4 GM to Ford adapters on ebay for $100, total cost is about $700.
GM BOLT PATTERN
Amazon.com
REAR Torq Thrust m 17x10.5 $163
44mm offset, needs a 1" spacer to sit near stock on the outer edge.
This give 6.5" BS, which will require major inner fender work.
FRONT Torq Thrust m 17x9 $154
45mm offset, needs a 1.75" spacer to sit like stock on the outer edge.
This gives a 5" BS, which has no issues
You need to buy 4 adapters on ebay for $100, total cost is about $750.
firstchoicewheelsandtires.com
Mickey Thompson SC-5 18x10.5 $248 (above my budget but it's soo nice)
54mm offsetn 7.88"BS, needs a 1.25" ford to gm adapter to sit near stock on the outer edge.
This give 6.63" BS, which will require major inner fender work.
Mickey Thompson SC-5 18x9 $233
32mm offset 6.25"BS, needs a a 1.25" ford to gm adapter, will sit like stock, no rubbing
You can buy the 4 GM to Ford adapters on ebay for $100, total cost is about $1075.
TIRES
Sumitomo HTR Z III 295/30/18 and 265/35/18 $692 shipped from tirerack.com
Decisions, decisions.....
FORD BOLT PATTERN
Wheelreplica.com
GM BOLT PATTERN
Amazon.com
TIRES
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: My research searching for wide 17/18" rims
I'm going to suggest that you put some more money towards tires - Sumitomos are not know for being good performers.
Car: 89 GTA
Axle/Gears: 4.10
Agreed, but the HTR Z III seems to have stepped up from the prior versions:
http://www.tirerack.com/tires/tests/...&affiliate=AH8
I'm also looking at EVO 12s or Vredsteins for a bit more coin.
I know you are in bad weather absent San Diego, so why not go for something $100 - $150 more a set and reap all the advantages a wider wheel and tire can give. BFG G-Force sports, Dunlop, Nitto, and Falken all make super excellent (but affordable) tires that will be 2 or 3 steps up from the Sumitomos or Vredsteins in performance...
Car: 89 GTA
Axle/Gears: 4.10
Thanks Paul -
I ended up going with the Torq Thrust M 18x10 and 18x9. Total cost $712 via Amazon
For tires I got Bridgestone S-04 285/35/18 and 265/35/18. Total cost $900 via Tirerack
I was going to get 255s for the front then I read your other post about our cars being front heavy so I reduced the stagger.
I'm currently running a 315/35/17 on back and 275/40/17 on front (Nitto R) and it really doesn't understeer too bad now, but going with the 285 265 combo should reduce it a little further.
Thanks Paul -
morrow
Jan 13, 2024 12:29 PM
rb85TA
26
Sep 14, 2015 10:29 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
