Iroc rim wheel lock key
Old Sep 23, 2013 | 10:08 PM
Napaman08's Avatar
Where could I find the wheel lock remover for Iroc rims on an 89 camaro. Also if I can't find key what's a good tool to break off nuts? Pics to follow tomorrow.
Old Sep 24, 2013 | 08:24 AM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Transmission: Automatic
Re: Iroc rim wheel lock key
I recently read that a 20mm 12 point deep-well socket can be coaxed over the offending lock with lubricant and a hammer. Haven't tried it yet though
Old Sep 24, 2013 | 09:23 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
the key for my '89 RS fit my '89 Iroc, i may have gotten lucky, as i dont know how many patterns were used from the factory
maybe try to find one in a junkyard car, you may get lucky
if not the 20MM 12 pt will work
Old Oct 1, 2013 | 12:09 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
i have and extra one, email me mgd6806@gmail.com
Old Oct 4, 2013 | 03:10 AM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
The socket and hammer trick works. You may need 4 sockets though if you cant remove the lug afterward.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
