weld wheels and tires?
Old Sep 30, 2013 | 05:28 PM
Chevyman454bbc's Avatar
Car: 1989 Camaro RS Hard Top
Engine: 305 Bored .30 over
Axle/Gears: Stock
I'm looking to get a set of weld rims for my 89 Camaro rs. I wanted to get the weld pro stars. I'll probly just get the 15 inch but I wanted to know for the rear what widest tire I can go with without any modifications to the rear end or the wheel wells. Also if u could help with the offset and backspacing thank you.
Old Sep 30, 2013 | 09:29 PM
88gunmetalgta's Avatar
Re: weld wheels and tires?
I used search and found out when I had this exact question... I'd tell you what I ended up buying, but I can't remember what backspacing I went with and I wouldn't wanna guess wrong and have you make an expensive mistake.
Old Oct 4, 2013 | 08:43 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
I'm using 15x10" with 5.5" back spacing have a Hoosier 275 60 on em, have used 28x12.5 et streets. Minimal "massaging"
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
forstral
Aug 19, 2015 03:20 PM
