Questions about 18's
Car: 1982 Camaro Z28
Engine: 5.7L 350 SBC
Transmission: TH350
So I've looking at wheels lately and have searched the forums before, and I had some questions about running 18's and their affect on fitment and steering angle. I'm stuck on whether or not its better to go with 18x8.5 up front and 18x9.5 in the rear, or to go 18x9.5 all the way around. also the wheels I'm looking at come with three different offsets and will sit on my car with either 0mm, or -15mm. my question is which will work best for handling and steering angle? from what I've seen I think the 18x9. all around with 0 offset would work good, but i worry about rubbing the inner well when at full steering lock, but idk if a -15mm offset up front is going to be very drastic or not. I get lost easy in all the numbers when it comes to wheel&tire fitment
and knowing which will compliment the car's abilities. Any input is appreciated, thanks!
and knowing which will compliment the car's abilities. Any input is appreciated, thanks! Supreme Member
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Questions about 18's
Order a pair of 9.5s with 0 offset for the rear, then try them on the front. Bolting them on isn't the concern, the concern is what you think of the result. Start with 275/35s for those 9.5s. Once you get that far, then you'll either know to order more of the same, or you'll have new questions for us.
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
