Check my math please
Old Dec 31, 2014 | 01:55 PM
killer777's Avatar
Car: 1989 Firebird Trans Am
Engine: 355
Alright, looking at wheels. I really like american racing torg-thrust M.
I have read article after article and come to the conclusion that I want to run a 18x10 with 5.5" Backspace on the rear and a 17x8 with 5.5" backspace on the front. Will this cause any issues with the fender walls, or suspension? Ride height will be stock. Any body run anything similar also and want to post pictures??
Old Jan 1, 2015 | 10:07 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Check my math please
The specs on the rear work, front will not clear with a 5.5" BS on a 17" wheel - you need something in the 4.5" to 5.0" BS.
One important thing to point out is how the car will handle with much wider tires on the rear than the front; you are going to get a lot of mechanical understeer.
Have you considered putting a 18" x 10" wheel and a 275 or 285 width tire on all 4 corners?
Old Jan 1, 2015 | 11:36 AM
killer777's Avatar
Engine: 355
Can I fit an 18" x 10" on the front as well? I was under the impression that I wouldnt have clearance.
Old Jan 1, 2015 | 04:16 PM
paul_huryk's Avatar
Yes.
There are a few members here with 18" x 10.5" wheels all around - assuming the BS is correct...
Old Jan 1, 2015 | 04:36 PM
killer777's Avatar
Engine: 355
Do you have any idea what backspace I would need to run to fit them? 5? Thanks paul_huryk
Old Jan 1, 2015 | 10:19 PM
paul_huryk's Avatar
For 10" wide wheels in 18", you would need something in the 5.75" to 6" range. They tuck the tie rods into the wheel barrel up front.
Old Jan 2, 2015 | 03:14 AM
killer777's Avatar
Engine: 355
Thank you for all of the help. I appreciate it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Nick McCardle
Sep 10, 2015 08:36 PM
