enkei rpf1
Car: 1991 Camaro Z28
enkei rpf1
anyone ever thought of running these wheels?
I see there are some 18x8.5 with ET40 and the 5x120 pattern.
Would the offset work?
thanks in advance guys.
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: enkei rpf1
1- wrong bolt pattern correct is 5x4.75 or 5x120.7
2- that offset wont work, you want a 0 offset
3- that rim isnt even offered in that size with those specs.
i would consider a different rim
Re: enkei rpf1
2. I am literally looking at them for sale in that size. you can't explain that.
3. thanks for answering the offset.
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Re: enkei rpf1
I think your best bet is the 18x10.5ET15 on 5x4.5 ones and redrilling them for 5x4.75 bolt pattern.
Maybe somebody (Paul?) could get a run of that size/offset made in 5x4.75?
Re: enkei rpf1
http://www.enkei.com/rpf1.shtml#
edit:... my tired eyes didnt see that listing on their guide but looking again.. its there, my bad lol
there is alot of literature on this site 5x120 and 5x4.75 fitment, but there are many cons and NO pros to running that bolt pattern. things like extra stress on the studs, vibrations, lug nuts not seating and loosening themselves are some of the issues.
not a great idea, but i do really like the rpf1s Last edited by 86iroct5; Jan 5, 2015 at 08:43 AM.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: enkei rpf1
Unfortunately, we can't get anything like that done. We can get you in touch with a custom wheel manufacturer that can cut anything in any size with any offset and bolt pattern in billet - just expect to pay minimum $1k per wheel.
Axle/Gears: 3.70
Re: enkei rpf1
You can redrill the 120mm to a 120.65mm one quite easily - just a elongation of the hole and possibly some wobble lugs.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: enkei rpf1
Depending on the pad design the 4.5 pattern can be altered to a 4.75 with proper machining and a pressed in slug.
whitedevilTA
Exterior Parts for Sale
Apr 8, 2011 10:01 PM
