Anyone do a minitub and use C7 Z06 rims yet?
Old Feb 22, 2017 | 08:56 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I have finished my minitub and plan to use C7 Z06 rims.
Replicas since new GM units are crazy money.
But think I will go with either C6 or C7 Z06 rims.
I would like to keep my front 9.5" wide or less, and the rears need to be at least 12" wide. I want to run 335s out back.
Looking to see if anyone has done this or anything similar.
These guys seem to have a lot of sizes available.
I would ideally like to go with an 8.5 wide up front. These guys have some styles to do that.
http://www.houseofwheelsonline.com/corvette_copies.php
Old Feb 22, 2017 | 05:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Anyone do a minitub and use C7 Z06 rims yet?
Not sure what the question is. Is it just a matter of if anybody has the same wheels or is there something else? Obviously you will need a spacer of some kind to correct the offset of the wheels, other than that, if the minitub is deep enough you should have no problem fitting a 335
Old Feb 23, 2017 | 08:18 AM
Engine: LS3
Yeah, re-reading my post it was sort of all over the place.
Basically wanted to see if anyone had C7 Z06 rims with 335s and a minitub.
Or maybe even just thinner knock off C7 Z06 rims to see what it looks like.
Old Feb 24, 2017 | 09:09 PM
the_hamturdler's Avatar
https://www.thirdgen.org/forums/whee...s-finally.html
That style looks off in 17's though, go at least with 18. That's what they look like, dont know about fitting 335's though
