New STR fitment help
Old Apr 14, 2017 | 07:58 PM
Chevyrunsdeep27's Avatar
Car: 91 Camaro Z28
So with 1.25 adpaters... the back of the rim doesn't come flush with the adapter... why? Because of the ****ing hub... how should I go about this?
1. Shaving the end all around of the hub a little?
2. Scarier longer adapters? (2 inch) (adapters needed either way for the hub clearing of thelse types of rims) (and different lug pattern)
3. Honing the center of the rim? Which would be the hardest
What to do what to do.... only needs a half a inch more of spacer/adapter
I'm getting these things for 500 bucks plus trade wheels I have around the house sounds like a good deal to me to pass up
Kinda on but not secure because of the gap left between the rotor and spacer Hand tightened wheel on, and thats the space gap between the back of the wheel and the spacer... the hub is keeping it from coming together cause the center hub boar is tapered
Shows the abrasion marks of how far it can go before the hub cant go further...
You can see the paint bung scrunthced and scrapped the center bore just being off by like a centimeter
Old Apr 16, 2017 | 07:25 PM
NoEmissions84TA's Avatar
Re: New STR fitment help
Do you have a technical high school with a machine/tool & die shop nearby?
This is exactly the kind of stuff they should like to do.
Old Apr 18, 2017 | 10:26 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
I would have the centers of the wheels machined for clearance.
Old Apr 22, 2017 | 08:58 AM
TennesseeIroc-Z's Avatar
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
I had the same problem on my old ford truck with front adapters, I just took a grinder and ground about a 1/4 inch deep- maybe 1/16 of material around the hub itself. Doesn't take much.
Now, this is my old "yucky truck", as my daughters call it, so modifications such as these don't scare me. And no vibrations or any funny business afterwards, drives just fine.
