Stack wheel spacers
Old Oct 15, 2017 | 11:29 AM
Firebat's Avatar
Stack wheel spacers
My 17x9.5 with 275 tires rub in the front. I think my wheels are 56mm which means I probably need a 2.25 spacer in the front. I have 2" bolt on spacers in the front and spacer has its own studs.
The question is would it be ok to run 1/4" slip on spacer on top of a 2" bolt on spacer?
Old Oct 29, 2017 | 08:21 AM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Stack wheel spacers
I don't suggest you do that. Just buy a set of 2.25" spacers.
Old Oct 29, 2017 | 10:03 AM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Probably not safe imo.
Old Nov 6, 2017 | 01:46 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
As cheap as spacers are now, I wouldn't. Put a 1/4 spacer on to check fit? sure. Drive with, No.
