Any pics with 19" wheels?
Old Mar 27, 2018 | 10:10 AM
Jeff TX's Avatar
Car: 1988 Camaro IROC-Z
Engine: Dart 427 w Miniram and AFR 225
Transmission: Stg 2 LT1 T56 w/ Spec Stg 3P Clutch
Axle/Gears: QP 9" (3.89) w/ TruTrac
I've been looking for pics of a third gen with 19" wheels. Has anyone actually put these on? I see lots of 20's and 18's but haven't seen any 19's. Pics please. And let me know your thoughts on ride. Are they significantly more harsh than 18's?
Old Mar 27, 2018 | 11:54 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Any pics with 19" wheels?
19” on rear 18 front
Attached Thumbnails Any pics with 19" wheels?-59a1982c-fb73-471c-a44a   Any pics with 19" wheels?-7762357b-323b-4e23-aea5
Old Mar 27, 2018 | 11:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Another angle
Attached Thumbnails Any pics with 19" wheels?-77134601-22c4-4f02-8a70
Old Mar 27, 2018 | 12:36 PM
Jeff TX's Avatar
Another angle
what size tires on the rear? How is the ride?
Old Mar 27, 2018 | 12:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Ride is fine. I had 295/30 street tires and now 305/35 drag radials
I feel shocks make the ride not the tires...to a point
Old Mar 27, 2018 | 01:58 PM
Jeff TX's Avatar
I'm about to order the double adjustable Viking Shocks/struts and put those on at the same time. What are you running for shocks/springs?
Old Mar 27, 2018 | 02:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Was on adjustable tokico for 10 yrs lol. Set stiff the ride was very harsh with the eibach springs. They were soft when set soft like when i went drag racing.
I even moved then to my 91 z28 that had stiffer spring global west stuff and ride was harsh on 16” stock wheels. Set light car was fine and the ride comfortable
I now have the high end valved viking double adjustable but car has no driveline in it yet so cant comment on the vikings. They are not meant to be set stiff however for street use, mainly for ultra high hp drag or very rough handling racing. Its their crusader valving. The streer warrior stuff will be fine when dialed in
Old Mar 27, 2018 | 04:40 PM
Jeff TX's Avatar
Hahaha, my car also has Tokicos at the moment. I never even heard of Tokico before I bought this car. Also running Eibach springs. I ordered the "Street" Viking shocks/struts. My goal is to have "decent" handling but I'll sacrifice a bit of cornering if it makes the ride less harsh. I didn't necessarily want to have 19" wheels but I needed to make sure I had wheels that would clear the ZL1 Brembo brakes. The 18s I was looking at were too close for comfort.
Old Mar 27, 2018 | 05:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
It will take trial and error lol but you will find a good setting for handling and can dial back for cruise if its too harsh
Old Mar 28, 2018 | 12:08 PM
Jeff TX's Avatar
Great, thanks for you responses. I'm feeling a bit more comfortable about ordering 19s now.
Old Mar 28, 2018 | 12:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Run as much sidewall as you can if you can fit it. Higher aspect ratio
Old Mar 28, 2018 | 01:25 PM
Jeff TX's Avatar
How much do you know on this subject? I was going to run 255/35/19 on the front and 295/30/19 on the rear which would be a 26" height. Other option would be 245/40/19 and 285/35/19 which puts me around 27". I thought that might be too tall for these cars.
Old Mar 28, 2018 | 01:44 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Interested where you net out Jeff.
I plan on C6 Z06 rims ( I have a mild mini tub) and am not 100% sure what size sidewall tire I will be running.
Once you buy and install parts, please post results.
Old Mar 28, 2018 | 01:55 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
That be like a 19x8 front and 19x9-10 rear?
295/30 has about a 3.5” sidewall height. 295/35 has about a 4.1” height
255/35 has 3.5”. So thats a good match to the rears 295/30. It will look good from the side
245/40 has about a 3.85” sidewall. 285/35 has about 3.9”. Also a good match and would likely ride abit better, but brands sizes and construction vary. Imo i like 27-28” tires on these cars. Gives clearance and traction but can be tougher to fit in the well when sizes get wider. Alot of hammering for 305/35 but it can be done, however this tire is 11.5” section width while other newer mickey 305/35 are 12.9. Big difference and same “advertised” size
My 295/30’s road nice and had decent traction. Bridgestone potenza. My 305/35 drag radials have a 4.2” sidewall and being a drag radial they are alittle softer sidewall tire so that helps with ride quality.
Old Mar 28, 2018 | 02:50 PM
Jeff TX's Avatar
Yes, the wheels are 8.5" in the front and 10" in the rear.
I figured I would have to decrease the tire width if I increased the wall height. Based on an online tire size calculator I've been using, the 245/40 and 285/35 would be 26.7" height on the front and 26.9" on the rear. If I do the original size I was considering, I'm going with the Michelin Pilot Super Sports. If I do the taller side walls then I'll need to switch to either the MichelinPilot Sport 4S or the Bridgestone Potenza S-04 Pole Position. All good tires from what I've read. If you think I can fit the 245/40s and 285/35s pretty easily then I'd be happy to switch to those.
Old Mar 28, 2018 | 02:51 PM
Jeff TX's Avatar
Will definitely post pics. Don't see many 3rd gens with 19s.
Old Mar 28, 2018 | 03:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah it will fit fine either way with the right backspace and alittle inner well massaging
Old Mar 29, 2018 | 06:03 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I won't say you can't go 19", but 18" seems to be the optimal size in terms of sidewall, tire availability, weight, and a few other things.
Also keep in mind that wheels and tires act as an additional spring and if you go too stiff (19" and above), almost everything suffers - ride, handling, straight line traction. There have been a few articles over the years where a car was tested on identical tires in different sizes (I think one was a VW on 15" up to 19") and the 17"/18" was the best in terms of driving and also performance.
Old Mar 29, 2018 | 07:15 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I will say I noticed a difference going from the stock 15" wheels to the 16" GTA wheels, even with Konis all the way around. The ride definitely changed for the rougher. I also notice an even bigger difference going from the 16" GTA wheels to the 17" Ronal wheels. 18 and 19's are going to be even more rough, even if you have a little more sidewall on them, all that additional unsprung weight and it is further from the axis.
Old Mar 29, 2018 | 10:28 AM
Jeff TX's Avatar
Now I'm second guessing myself. Definitely have some bias towards Orr89's responses but pretty much every other 3rd gen person I talk to keeps trying to steer me away from 19s.
Old Mar 29, 2018 | 10:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Just my experience thats all. I’ve had the same shocks and springs on stock 16” wheels and my 19’s. 2 different type of tires. My one car has roll bar and subframes. Its a stiff chassis car compared to my bone stock 91 z28. Softer stock spring rates and shocks set light seemed to damp well imo.
I have run 17’s on my 99 trans am i had. Stiff springs and bilstein shocks i felt it rode very well. Softer than my iroc since i drive my iroc set stiff and aggressively but i could always dial it down.
Everyone will have their own experiences and comfort levels so take with grain of salt
Old Mar 29, 2018 | 02:25 PM
Jeff TX's Avatar
I hear you. I remember when I first bought my car, the previous owner talking about how the ride was waaayyy too rough for his taste. Then I drove it and thought it was extremely comfortable. I ordered one 18" wheel today. I'm going to test fit it over the ZL1 brakes. If it doesn't fit then the decision is made for me because I am 100% putting those Brembos on my car.
Old Apr 2, 2018 | 12:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I will be running 19" wheels on all fours after striking out trying to fit C7 Z07 Cup Wheels.
Orr, what tire size do you have in those pics above? I am shooting for a 26.3" tall tires front and rear but am wondering if I should go taller.
Old Apr 4, 2018 | 11:35 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
The fronts were 255/40 i believe. The rears in those pics SHOULD be my mickey et street radial 2’s that are 305/35/19. This tire is 11.4” section width and fits fine. They have been discontinued however and replaced with et street ss which are also 305/35 BUT they are advertised at 12.9” section width which is much wider so if you plan to go that big you will want to measure closely. Its over 27” tall.
Old Apr 4, 2018 | 11:39 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Here was a 26” 295/30 rear. Sidewall did not match size and looked odd to me
Attached Thumbnails Any pics with 19" wheels?-d3ca2b58-1d5a-4323-8d41
Old Apr 4, 2018 | 02:31 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It looks good in the picture but I am sure the sidewall height difference looked odd in person (assuming that is a 255/40/18 in the picture). I think I've settled on 26.3" tall front and rear with the following.
265/35/ZR19 on a 19x9
305/30/ZR19 on a 19x10.5
My back end is mini-tubbed so I have plenty of room in the rear. More worried about height fitment up front (I currently have a 245/45/17). I figured if I landed in between 26 and 27 I would be ok. Both would have 3.6X sidewall height. Maybe I should go taller in the rear, and or shorter with a 30 series up front. Tire options are indeed limited with 19's.
Old Apr 8, 2018 | 04:33 AM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
19x9.5 - 10.5 with 35 series
Old Apr 8, 2018 | 04:38 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
295 rears and like 255 front iirc could of went wider on front for sure and alittle more aggressive on offset as well and if I did it over again would be a square setup of 10.5 all around
35 is about right all around I think 40 would be too much and with lower ride will run into issues with front and rear
Also I’ve had both 18s and 19 in my sig are 18x10 all around as well I both 19s and 18s felt the same with 35 if I did 18s again would do a 40 because the taller tire fills wheel well so much better and prob be best ride with taller tire as well with saying that I think the 19s look sick from the 19s with the perfect stance my wasn’t perfected but yea
With all said in done looks wise 19s have the cake with the cherry and ice cream , performance wise 18s will be the best option due to tire selection and lighter weight and more room for taller and or shorter tires combinations and if you plan to track
But can always have you track tire set as well lmao js
Old Apr 8, 2018 | 08:04 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
That does look great. What tire widths are in those pics? And are those pilot sport 2 cup tires?
Old Apr 10, 2018 | 01:15 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
255 front and 285 rear I could go wider and yea sport cup great tire hard to break loose and predictable really have to do some crazy stuff
Old Apr 10, 2018 | 01:18 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Side angle
Old Apr 10, 2018 | 02:13 PM
Jeff TX's Avatar
Side angle
So you have 255/35/19 and 285/35/19 on this car? Any shots directly from the side? Some of the other pics you posted don't seem to be showing on my computer.
Old Apr 12, 2018 | 10:25 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
You have to pay photobucket now to post pics smh what else can I use
Old Apr 12, 2018 | 10:28 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Just attach pics again haven’t been active in community or forum things have change I guess with photobucket
Attached Thumbnails Any pics with 19" wheels?-3743e481-fbbc-4dc9-ae3f   Any pics with 19" wheels?-163d5989-508c-48fe-b129   Any pics with 19" wheels?-f093cf06-2229-434f-9163   Any pics with 19" wheels?-c23bd977-5e27-4857-8e0b   Any pics with 19" wheels?-772e80fb-1c2e-4907-8460
Old Apr 12, 2018 | 10:36 PM
Jeff TX's Avatar
what tire size on the black car? Are those 285/35 or 285/30 on the rear? 255/35 on the front?
Old Apr 18, 2018 | 01:36 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
35s all around didn’t like the 30s
Old Apr 18, 2018 | 03:48 PM
Jeff TX's Avatar
Cool. I ended up ordering 285/35/19 for my rears. Haven't decided on fronts yet. Will either do 255/35/19 or 245/40/19
Old Apr 27, 2018 | 06:37 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea that will doo
Old Apr 27, 2018 | 06:59 PM
Jeff TX's Avatar
Yea that will doo
ended up ordering the 245/40/19s for the front. Hopefully they fit without rubbing. Rears came in yesterday. The fronts should hopefully be here by Monday.
Old Apr 27, 2018 | 07:02 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
They will fit and will be taller as well but sure if you will like the look and as long your not really low it should be fine worst case you have to remove the fender liner for sure for extra clearance for suspension travel if your super low
Old Apr 27, 2018 | 07:05 PM
Jeff TX's Avatar
My Car is lowered but not too crazy.
Old May 4, 2018 | 11:25 AM
  #42
Engine: 305 to 350
Axle/Gears: 10 Bolt
looks like a 1" drop so yea shouldn't be to bad
Old Jun 2, 2018 | 09:15 PM
  #43
Jeff TX's Avatar
So I ended up going with 245/40/19 and 285/35/19. Unfortunately they sent the wrong tires (235/40/19) but I decided to put them on any. They ride is fine. I probably could have gone with shorter tire walls but I prefer the height of these tires. Fills out the Wheels wells better in my opinion.
Old Jul 27, 2018 | 09:56 AM
  #44
Iroc-Ian's Avatar
Car: 87 Camaro IROC-Z
Engine: 5.0 305 TPI
19x9.5 all round with 275/35/19
Old Jul 27, 2018 | 11:22 AM
  #45
Jeff TX's Avatar
Do they rub in the front? If not, did you have to do anything special? my 235/40/19s rub.
Old Jul 27, 2018 | 12:13 PM
  #46
Iroc-Ian's Avatar
Engine: 5.0 305 TPI
Haven't done anything and all I have is rub on full lock
Old Jul 27, 2018 | 12:54 PM
  #47
Jeff TX's Avatar
Yeah, mine doesn't rub in normal driving but rubs on u turns and when I'm parking. Kind of annoying but doesn't cause too much hassle.
Old Aug 1, 2018 | 04:11 PM
  #48
7_ws6ta_9's Avatar
285/30/R19 all the way around
Old Aug 1, 2018 | 04:15 PM
  #49
7_ws6ta_9's Avatar
Old Aug 7, 2018 | 07:43 PM
  #50
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Just out these on. 19s rear. In the rear i have a 4th gen rearI had to use a 5/16 spacer but going to a 3/8 or 1/4 spacer.
the wheel well was “massaged previously.
Does anyone here use a spacer or should I get longer studs ? It’s not a track car but a weekend driver
