I recently bought a rear axle out of a 2002 Z28 and I've read that you have to be careful about the rims you choose to avoid rubbing. I've been looking at C4 ZR1 rims and I'm not sure what the right offset would be for the rears. I'd also like to avoid having to go at the car with a hammer to make space if possible.
Stock rear wheels on an Iroc are 16mm offset. ....as the offset goes up, the wheels move in towards the car.
Stock 4th gen rear is wider, so stock Iroc wheels would be pushed out. ...you want MORE offset, for a stock appearance/fit. I believe 4th gen wheels are 55mm. I believe the C4 Zr1's are about 50 t0 55 as well, so they should fit, but please double check the math on all this.
427seven
close
- Join DateJan 2019
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1989 Firebird GTA
- EngineMotown Aluminum 427
- TransmissionTH400/GVO
- Axle/GearsDana 44 IRS 3.75:1
- Liked:507 Times in 244 Posts
it's not just the fit on the rear that you need to check, you need to clear the car as well. buy (or build) a mock up tool, make sure everything clears before you put $ down on something you can't easily unload if it doesn't werk....
Totally agree with 427, we're talking about the back, but yeah....any wheel different from stock should be measure and checked. Corvette fronts will definitely have way too much offset, though spacers will work if you feel comfortable with them. Stock is easy. Cut and dry, black and white. Anytime you deviate from stock....well.....welcome to hot rodding!!!!
Quote:
I ran a full set of 17x9.5 C4 ZR1's on my car for many many years and then swapped the rears out to the 17x11s when I did the 4th gen rear. I can probably answer most of the questions you have if you need. Here's a few pictures of them on the car.Originally Posted by ElCeejo
Camaro82.....so those last pics are 17x11, WITH...the 4th gen rear? ...how do you think those 17x11 woulda worked with the thirdgen rear? Not enough clearance? That would be my guess. I swore my first Iroc would always have Iroc wheels. ....this new 88, I'm more open to different things, and I've always like the SS/GS/Zr1 wheel.
Quote:
Thats correct, the 17x11s were only used on the 4th gen rear, and I only had a few inches of clearance from the inner fender well. The only way they would work on a 3rd gen rear is with a 1.5 or 2 inch spacer. Originally Posted by Abubaca
Camaro82.....so those last pics are 17x11, WITH...the 4th gen rear? ...how do you think those 17x11 woulda worked with the thirdgen rear? Not enough clearance? That would be my guess. I swore my first Iroc would always have Iroc wheels. ....this new 88, I'm more open to different things, and I've always like the SS/GS/Zr1 wheel. I appreciate the response, and that makes sense. ...what size tire is that up front? Looks HUGE! lol!!
