Biggest tires size
Old Feb 15, 2021 | 06:33 AM
87TCamaro's Avatar
Car: 87 T top iroc z28 camaro
Engine: 355
Transmission: 700r
Axle/Gears: 27spline factory 9 bolt w 355 gears
Biggest tires size
Hey everyone I'm gonna get 18 inch iroc Tim's for my Camaro and I was looking at tires and found some 275 40 18s. My question is would that fit in the front with the standard iroc width being 8.5 I believe...any help is appreciated thanks
Old Feb 15, 2021 | 07:16 AM
Abubaca's Avatar
Re: Biggest tires size
The stock diameter is "about" 25.75" tall. A 275/40/18 is about 26.75". I might recommend going with a 275/35 instead of a 275/40.
As for width, a 275 will be really close to fitting with no issues (assuming you keep the overall diameter stock). You might need a .25" spacer to clear the tie rod. Some need it, some don't, but running a 275 is pretty common.
What is the wheel width you're buying? I though most the 18's were only 8" wide, which wouldn't be ideal for a 275 tire. Maybe there are more options out there these days.
Old Feb 15, 2021 | 07:21 AM
87TCamaro's Avatar
Engine: 355
Transmission: 700r
I wish it wasn't 25$ for those tires haha 275 35s are more expensive then 275. 40s
Old Feb 15, 2021 | 03:31 PM
Abubaca's Avatar
It may fit.....but my guess is that it won't, at least not up front. Some guys get some tire rubbing....some run into the tie-rod. That may not be an issue with an 18" though. It's hard to say. Thus the fun of fitting different sizes.
Old Feb 15, 2021 | 03:33 PM
87TCamaro's Avatar
Engine: 355
Transmission: 700r
Whole reason is I'll be doing a big brake kit upgrade and I need bigger rims...also fatter tires haha
BigBlock73
Wheels and Tires
Apr 20, 2018 11:07 PM
D_Mos
Wheels and Tires
Feb 22, 2010 03:09 PM
nascar2496
Wheels and Tires
May 12, 2009 09:48 PM
Bowtie-Bri
Jun 22, 2005 06:20 PM
1985_glue_factory
May 2, 2002 04:50 PM
