lg4 fuel pump installation help PLEASE!!!!!!!!
Old Jul 26, 2000 | 07:29 PM
silvermelon's Avatar
right now the car hasno fuel pump. the old one came off easy, and the new one refuses to go on. if we get one bolt going, we cant get the other one on because it wont line up. is there any special way to get it on, because its not working.
Old Feb 18, 2005 | 06:08 PM
Thumpin455's Avatar
Car: 70GTO/79Formula/98Formula
Engine: 455/467/LS1
Transmission: TH400/4L60E
check to make sure its the same model fuel pump
Old Feb 18, 2005 | 06:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Are you pushing the fuel pump pushrod up out of the way?
Old Feb 18, 2005 | 07:19 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
You need to push the fuel pump pushrod into the block and hold it in place while installing pump. Use an old hacksaw blade, bend the end, and slide it in to hold up the rod. Install pump and start bolts. Remove blade and tighten bolts.
Old Feb 18, 2005 | 08:14 PM
Pony Killer's Avatar
Car: 1986 Z28
Transmission: th400
i'll usually take some white lithium greas and slather the pump rod with it, so it'll slide in easy, you may wanna bump the motor around a lil bit. it may be all the way up on the eccentric on the pump cam making it harder to compress the spring, in the fuel pump. if it's the right pump. once you bump it around, like one turn, you slather it up with some white lithium so it stays up in the block you bolt it up and call it good.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
