Spindle mod Q's
Old Feb 14, 2005 | 10:09 PM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
Spindle mod Q's
Hi, I have a few questions......
1. How do you modify the spindles on a camaro to use 1LE rotors?
2. Can I do this myself?
3. Will I compromise the strenth of the spindle?
4. Are the GM 1LE spindles just modified stock spindles or are they worth the big bucks to buy them right from GM?
Thanks in advance as always....
-Mike
Old Feb 15, 2005 | 01:29 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
It really is very very simple to do. When you cut ooff the excess material of the stock iron caliper spindles, it is not critical that they be cut at a perfect angle accordining to the reference dotted line below. Just hack away leaving adequate spacing of metal material from the holes needed to be tapped. cut leaving about minimum 3/8" away from both holes to insure strength, yet you could cut leaving as much as about 1" away.
Attached Thumbnails Spindle mod Q's-c-documents-settings-office
Old Feb 15, 2005 | 01:33 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
You can see here how I grinded the cut off sections more rounded after I altered them. I made sure that the washers were installed flat onto the surface area and that I grinded around them not touching them or the area under them. This is a good reference when cutting off the ears.
Old Feb 15, 2005 | 06:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's a link that may provide some useful info. AndyZ28 also offers a 1LE CD (mentioned in this month's Chevy High Performance). The mod is an easy matter as RTFC mentions. The true 1LE spindle hasn't been availabe from GM for some time.
http://www.ws6transam.org/1LEbrake.html
JamesC
Old Feb 15, 2005 | 07:16 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Are you sure that 1LE used 3/8"-24 UNF?
Just that when I did the conversion I did it to M12 according to the instructions that came with the spohn 13" pro series kit, which I thought used the same 1LE spindle mod.
Just curious, as it probably doesn't matter much as long as you have the bolts to match the threaded hole you make. Probably just an oddity with the pro series kit, but thought I'd ask.
Simon.
Old Feb 15, 2005 | 08:26 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
bingo.
Old Feb 15, 2005 | 08:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Simon.
I don't care for that either. Two 3/8" bolts holding the entire torque of the front brakes? Still in the middle of a C4 conversion, however, I made the upper bolt a 1/2"-20 and the lower a 7/16"-20, both grade 8.
RBob.
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
jdperformance
Sep 16, 2015 11:55 AM
rb85TA
26
Sep 14, 2015 10:29 PM
