What Ibs injectors are these?
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
This last summer I found a caprice with a Lt1 motor in it so I took the intake home with me to convert it and now I'am wondering what size injectors it came with. At the time I tried to look for some numbers at the back of the motor to find out if it was a 5.7L but I really didn't know where to look but I do have the part numbers of the injectors here, out of the eight 7 are 17095004 and 1 has pn# 17124187.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Axle/Gears: 3:73 Posi
I do hope it isn't a 4.3 Lt1...no such thing...is there???
Ummm, do you have a picture of these injectors. Look on the engine block itself at the back by where the ditributor goes in...it should be printed right there if it is a 5.0L or a 5.7L. HTH
Keiran
Ummm, do you have a picture of these injectors. Look on the engine block itself at the back by where the ditributor goes in...it should be printed right there if it is a 5.0L or a 5.7L. HTH Keiran
Car: 89 GTA
Well its to late for me to look at the block since I took it out of a car in toronto when I was visiting there this summer but I can tell you what they look like, black with dark grey on the bottom.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
There is a 4.3L 265CID LT1. aka "baby LT1" It probably uses 19lbs injectors. While a 5.7L 350CID LT1 uses 24lbs injectors.
BLOCKS
350 - There are two blocks, one with two-bolt mains and one with four-bolt mains. They both have the same 10125327 casting number, so there’s no sure way to know which one you have until you get the pan off. However, if it came out of a Corvette, it should be a four-bolt block, and if it came out of anything else, it was supposed to be a two-bolt. GM used the two-bolt block for everything but the Corvette because it had plenty of strength and it weighed a little bit less.
265 - There was only one block used for the 265 cid version of the LT1. It’s a 10168588 casting that had the numbers "4.3" cast on the side, too. It’s real easy to spot if the heads are off because of the small 3.74" bore.
BLOCKS
Engine: T.P.I L98.
Very interesting! Never heard of that 4.3l V8 Then agian I don't go around playing with Caprices either. Thanks for the info.
Keiran
Keiran
search for both those part #'s on these two pages..
http://www.tecnomotor.com.br/princip...azao-TM503.htm
http://www.powerpage.dk/produkter/pic/injectors.pdf
they are definatley corvette injectors.. but thats all i know
Car: check
Engine: check
Transmission: check
Re: What Ibs injectors are these?
RBob.
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Originally posted by KDoggsPimpJetta
ahh didnt they use 4 bolt main blocks in trucks there bud???
thejimsterz28
Sep 15, 2015 04:37 PM
