1LE with Rear Drum
Old Mar 26, 2001 | 10:36 AM
Fao's87T/A's Avatar
1LE with Rear Drum
I have all the parts for the front swap. What proportioning valve should i use cause i have rear drums ? I was thinking of using an adjustable one. But could i get away with using the stock one.
Old Mar 26, 2001 | 10:47 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I wouldn't run the front 1LE brakes with rear drums. You're better off waiting and converting to 4-wheel disc, then getting a 1LE proportioning valve. I haven't a clue what type of valve to use with rear drums, but I'd say stay with the stock one...it's a 60% front, 40% rear bias, and since the front's are meaty, you're better off that way. 4 wheel discs are 50%-50%.
My $0.02.
Old Mar 26, 2001 | 11:14 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I'm running front 1LE brakes with stock rear drums with no problems. Both still put out brake dust, and they worked fine on a road-race course with race pads up front. I used the stock proportioning valve and the braking still feels very balanced.
Greg Westphal
'87 IROC 305TPI/A4
jaridjohn
Jul 8, 2024 03:49 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
