cruse rpm
Old Jun 23, 2002 | 12:59 AM
RBud350tpi's Avatar
cruse rpm
My 87 has a 350/700R4/3.27 gears, my 89 has a 305/T-5WC/3.08 gears. the 87 cruises 60 mph at about 2000 rpm and the 89 cruises 60 at about 1600 rpm. do you all think the 87 is in the right range or could 4th be slippen a little? Is it like comparing apples and oranges cuas of the different trannys?
Rich
Old Jun 23, 2002 | 03:22 PM
Rustynutz's Avatar
It's hard to beilieve that you cannot see why. Could it be the difference between a 3.27 and 3.08 ratio? yes. Thats the answer, that and the difference in final drive ratios of the different transmissions.
Old Jun 24, 2002 | 01:07 AM
RBud350tpi's Avatar
well I knew the different ratios were the main reason but I did not think there would be that big of a difference between the two. I just want to know if I am on par with other 3.27 auto set ups. I also thought the over drive in the trannys were about the same. .7 to 1 for the 700R4 right?
Rich
Elephantismo
Feb 13, 2019 12:51 AM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
wisemanz28
Sep 20, 2015 01:26 PM
