Updated pics of my 4th gen dash swap,actual pics of functional dash.
Old Jan 27, 2004 | 03:42 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
well here they are,some of you guys called BS on my post in the apearance board saying it didnt really work,or its impossible they dont work,anyways on to the pics... btw,im still writing u pthe tech article for all you lazy people
daylight pic
night time illumination pic
it looks funky in the pic,its alot brighter in person,well it lights up just like a 4th gen dash
another illumination shot
Old Jan 27, 2004 | 06:17 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Well Mark It looks like you have a very functional 4GEN dash swap. Congrats!! Now The reason I am Wondering about the Wiring and how you made the HVAC Controls functional is because my camaro is the only car i have to drive so it can't be out of comission more than 3 days. With a explanation of the wiring and HVAC controls I am confident I can do this Properly with out RIGGING any thing. Any Help Would be appriciated.
Thanks for the info
Old Jan 27, 2004 | 11:24 AM
Bandit5's Avatar
Excellent work, Mark. Now all we need is easy to read/follow wiring diagrams for the different model years and such.
Also, someone should really figure out what clusters work with what, i.e. 97 cluster in 98+ dash, 94 cluster in a 97 dash, 93 cluster in a 00 dash. And also which clusters are easier (or damn near impossible) to wire. If we could get this information, I could write up a really good FAQ/Tech article.
Old Jan 27, 2004 | 12:41 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
if we can get some clarification on how well the console fits with the dash (96 version to 96 version -- or 97+ version to 97+ version), that would be great. Right now I've got a 97+ console and a cracked dashpad... So either I'm going to redo an old console and recover the dashpad (never tried before - who knows) and get rid of the 4thgen console completely (don't think it fits well with the lines of the dash), or do a propper 4thgen dash installation. All the pictures you can possibly take of the fitment, wiring, etc. I will host on my webspace for free.
Old Jan 27, 2004 | 07:52 PM
MarkB's Avatar
Engine: 383 -305
alrighty,will do...like i said im in the process of writing up the tech article detailing everything needed to be cut/spliced,or re wired in general,as well as vaccum routing,btw,i only have mine set to work the defroster and vents,i might get the floor heat worked up...there is quite a bit of fab work to get the ducting right,and its almost impossible to line out a tech article for that,but i will try too.
ill continue posting progress pics i nthe next coming weeks however,im very busy with my auto shop,usually dont get to work on my personal cars until the weekends or late at night when im closed.
but have no fear,ill get er done
Old Jan 27, 2004 | 09:19 PM
MarkB's Avatar
Engine: 383 -305
w00t
Attached Thumbnails Updated pics of my 4th gen dash swap,actual pics of functional dash.-112484685inuqcv_ph.jpg
Old Jan 27, 2004 | 09:38 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Impressive. How many hours have you spent working on it so far?
Old Jan 28, 2004 | 01:38 AM
MarkB's Avatar
Engine: 383 -305
heh,ill break it down like this..
tearing the old dash,console out- 30 minutes
getting the general fitment of the new dash in-about an hour
finalizing some mounting points and fabbing up some new mounts to make it more secure,about another hour
actually test wiring the dash gauge cluster WITHOUT cutting my stock harness,about another hour
after the test wiring,and double,then triple checking and labeling everything,i hardwired everything in place,that took about 2 hours
once that was done the reinstallment of the dash was done,i checked everything back over,made sure i had plenty of clearance for wires and everything,then i yanked the dash back out,put in a new heater core{which took 10 minutes hehe} the reinstallment {mock up} took about a half hour
then theres wiring up the hvac controls,which is EASY,and rerouting all the vaccum lines to the proper solenoids{ for my application and preference} this took ,maybe 20 minutes
then the headlight switch wiring,which i still havent gotten to work 100% yet which pisses me off,i can get EVERYTHING to work off the headlight switch,EXCEPT the headlights wont go back down! ,this is the only thing im currently still working on.
if you add up all the misc things ive done,and redone because of a goof up,or just double and triple checking things,i probably have about 10 hours into it roughly.
im still nowhere near done,i have to tear the interior out so i can put the new carpet kit in when it gets here.
this is actually an easy swap to do,just takes alot of patience. its not something id really recomend anyone to just go out and do,its going to depend on your skill level and ability to follow wiring diagrams and the like,i found myself thinking WTF have i donewith my car?!...the amount of wiring under the dash and the amount of resplicing can be somewhat overwhelming.
pretty much everyone in my town loves the dash,my buddy who came down to hang out at my shop for the weekend saw it and was like BADASS! we drove it over to the gas station where a few friends of mine work,and he had no idea i had swapped it in until he actually looked farther into the car and saw the cluster all lit up,and his response was holy shiat! ]
btw guys,im working right now im this tech article
Old Jan 28, 2004 | 09:27 AM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
great...just great...
a tech article from the one and only trailerparkspecial.
j/k looks good, you just better not come back with a 180hp dyno sheet this time
Old Jan 28, 2004 | 11:13 AM
Car: 1987 GTA
Transmission: 4L60e
I'm waiting on it. You're gonna make me pull my interior out again..
Old Jan 28, 2004 | 02:18 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Looks great.
One question though, the volts look really high in your pics.
Is the gauge wrong or is it really putting out almost 18volts?
Old Jan 28, 2004 | 02:21 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
My '93 Beretta GTZ puts out almost 18 volts. At least thats what the guage reads.
Old Jan 28, 2004 | 05:04 PM
MarkB's Avatar
Engine: 383 -305
Originally posted by Zepher
Looks great.
nah,its right at 14.5 volts,i thought it went up high too
the middle is 12 volts,then the next indicator is 14 volts,the next ones 16 volts
andmayhem,i put down 200 hp last year
this 383 better double that or im going to be pissed
Old Jan 28, 2004 | 05:37 PM
Zepher's Avatar
If my little brothers car starts up tonight, I'll snap a pic of where his needle sits. If I remember correctly, it was close to the second marker between 13 and 18, but it wasn't past it.
my 2 clusters have 13 in the middle.
Old Jan 29, 2004 | 12:24 AM
MarkB's Avatar
Engine: 383 -305
heh,yeah...you got me thinking about that...i forgot to mention i have one of the powermaster 140 amp alternators
Old Jan 29, 2004 | 01:06 AM
Zepher's Avatar
If I am not mistaken, stock LT1 alternators are 140amps, aren't they?
Old Jan 29, 2004 | 02:43 AM
MarkB's Avatar
Engine: 383 -305
if im not mistaken,i thought the LT1S got the 110 amper,and the b4c/1LE cars got the 140 amp?
im not totally sure.
Old Jan 29, 2004 | 09:45 AM
Car: Camaro
Engine: 355c.i.
Transmission: th350
B4C got 140...i dunno about lt1 tho...
Old Jan 29, 2004 | 10:53 AM
Zepher's Avatar
This is a listing of the stock replacement alternators for a 95 Trans Am,
Premium P817273
Remanufactured; Pulley: 6S; Amp: 140; Mfr: DR; Fan: EF; Reg: IR
Lifetime Replacement Warranty Ships in 1 day
Weight: 15 lbs.
$139.88
$60.00 core
AC Delco 3211113
Remanufactured; 140 Amp; Stamped 10480203
Weight: 17 lbs.
$148.29
$65.00 core
Beck/Arnley 1866180
Alternator: Reman.; 140 Amps; Serpentine 6 Groove
1 Year Limited Warranty Ships in 2 days
Weight: 11 lbs.
$135.99
$68.50 core
Bosch AL8573X
Alternator: Reman. Repl.; 1st Prod.; 140 Amps Delco Remy System, Plug Config. DR3, Inter. Reg.
Weight: 10 lbs.
$225.99
$55.00 core
Bosch AL8573X
Alternator: Reman. Repl.; 2nd Prod.; 140 Amps Delco Remy System, Plug Config. DR3, Inter. Reg.
Weight: 10 lbs.
$225.99
$55.00 core
Autolite Pro 142967
Lifetime Warranty with 24 Month Road Service Ships in 1 day
Weight: 16.7 lbs.
$169.99
$40.00 core
Old Feb 6, 2004 | 12:06 AM
Gecz28's Avatar
Car: 88 iroc vert
[B]Damn- 157mph@-200rpm!
lmfao
Ghettobird52
Jul 5, 2024 11:18 PM
Jorlain
Aug 24, 2022 05:11 PM
Casey Meyers
Mar 2, 2016 10:46 AM
justin57
Aug 20, 2015 07:05 PM
redmaroz
Aug 16, 2015 11:40 PM
