4th gen interior in a bird
Car: Trans Am GTA
Engine: 5.7L TPI
Transmission: TH-350
Axle/Gears: 3:23
I got the front seats mounted in the front but im sure everyone is aware about the backseat not being able to mount. Has anyone made a bracket or know how i can install the back seat???
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Yeah, I thought the rears went in with no problems, too, at least that is the impression I had from reading posts around here. I'll be curious to see where this goes...
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
the back seat from the 4th gen is alot more narrow than the stock 3rd gen. Unless someone knows something i dont then please show me the steps to help me out
Car: 91 formula
Transmission: t5
Engine: LT1; None
Maybe if you could post some pics, it would help, because you are saying they are too narrow, and others are saying they are a bolt in. Either you have the wrong seat, or...?
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I have heard after some research that the rear seats are slighly smaller, barely noticable. They do bolt in with out a problem from what I hear. I think I read they are in about an inch on each side.
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
ok well i payed a little more attention to the back seat tonight. I got both bolt on the bottom in the holes. But now the hinges at the top wont latch.
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
the 3rd gen "posts" that the back seat hooks onto does allow for some adjustment. I haven't installed 4th gen seats yet, but I have swapped interiors before and if you lossen the post a little you can reposition it slightly and tighten it back down. maybe that will help you align it with your new seat back.
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
I've bolted in 2 sets of 4th gen seats in my car and neither required any modifications to fit. Did you have split seats before, and maybe the new seat is hitting the middle studs?
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
Car: 1984 Trans Am
some people say you have to cut the metal piece in the middle if you had a split rear seat. others say it won't interfere. I had no problem going from split rears to a solid 3rd gen rear seat in my 84 T/A.
Originally posted by Zion
split meaning there is two seperate bucket seats in the back right? i thought this was normal for all 3rd gens...?
Car: 1991 Red Trans Am
Transmission: 5 spd manual
No, it was a 60/40 split bench back in the thirdgens. And no, it wasn't the standard either.
The 60/40 split bench back was not standard, but the two rear seats/seat wells are in all 3rd Gens
just thought I'd clarify a little
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I may be stupid (which is questionable at times) but, I could swear the original spilt back that was in my 'bird was spilt in the center (thus the mount centered on the rear driveshaft tunnel). Which, by my old math calculations, would equate to a 50/50 spilt seat due to it being in the center, no ?
Or, was there more than one style split rear seatback ?
I also thought the split seatbackwas part of the 'deluxe' interior upgrade as well but, I'm not a historian about things like that. Probably wrong about that too though.
As far as fit... didn't have a problem in either of my cars...
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
I didn't have the split rears, but the 4th gen bird seat was a direct bolt-in. However, the 4th gen seat backs are slightly lower than the 3rd gens. It probably isn't really noticable in a coupe - but it was in the 'vert as there now is a bigger opening between the tonneu cover and the seat back than it was with the stock seats.
I guess maybe a couple of pics speaks more than ......
3rd gen rears:
4th gen rears:
Ken
3rd gen rears:
4th gen rears:
Ken
Engine: TPI 305/ v6
im confused
im confused
j/k
split... as in the upright of the backseat is in two seperate folding pieces (like newer cars have to access the trunk from inside).
A visual.. (image swiped from Hawks)...
Engine: TPI 305/ v6
oh... mine has that thing going across between them. the whole back folds down.
what do fourth gens have again?
Years prior to the rear seatbelts though (just assuming here), the one piece soild back only had one catch hook. My 84 SC only had one catch at least. My 91 has rear shoulder belts and had catches on both sides, like the 4th gen.
My bird had them on both sides as well due to it having the split folding seatbacks.
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
My Camaro is by no stretch of the imagination a 60/40 split...
It is 50/50, right down the middle.
I didn't know that all 4thGen seats were solid backed. That's discouraging to me... I planned on swapping to 4thGen seats, but I really like the 50/50 split seats I have.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
ambainb
Apr 25, 2016 09:21 PM
